#4 cyl miss
PostPosted: Tue Sep 21, 2004 8:43 pm    Post subject: #4 cyl miss Reply with quote
I got my truck with me in Vegas. Yesterday the #4 cyl had a miss. (pulled wire from cap no change) So I pulled the throtle body, pulled #4 and #5 plug. Checked gap(same) not fouled, and had spark. So I swapped the plugs from #4 to #5 and #5 to #4. When I started it it ran great again. Till I shut down the truck. Wen I started it the miss was back. So I drive it anyway. Up by red rocks, on the 4x4 gravel road. over the pass 6430 ft, then down the other side ran bad all day till it got close to the hotel, and it ran fine again. I got back to the hotel and shut it off. I started it right back up and the miss is back. Same #4
So I am going to swap wires and see if that works. Any other advice???
Cap looked fine, but I may swap it too.
PostPosted: Wed Sep 22, 2004 7:23 pm    Post subject: still broke Reply with quote
I started the truck, and it ran fine. But I decided to swap the wire anyway, and it ran fine for a while. till I shut it down and when I started it again the miss was back?
Any ideas what to look at next?
PostPosted: Mon Sep 27, 2004 12:18 pm    Post subject: Reply with quote
yikes, I missed this one. Probably not in vegas anymore. Did you ever figure it out. Might want to replace your cap and rotor.
PostPosted: Tue Sep 28, 2004 9:04 pm    Post subject: maybe fixed Reply with quote
Boosted from 4x4wire made the sugestion of the FPU VSV. I didn't see a problem, but I pulled the wire conector off, and put it back on. Then I also fixed the conector on top of the Tstat housing, It was loose. Drove it till it got warm, and it seems to be fixed.
I am still in Vegas. I hope to be here till christmas, maybe more. Going to the Hammers in the middle of October. Also plan to go to Glitter Gulch TLCA event.
PostPosted: Wed Sep 29, 2004 1:27 am    Post subject: Reply with quote
oh really? So you going to be there for the Vegas Supra meet? I will be there with my new project I am working on.
PostPosted: Wed Sep 29, 2004 8:02 pm    Post subject: supras in vegas Reply with quote
When and where is it? I wil show up if i'm here.
PostPosted: Thu Sep 30, 2004 4:22 am    Post subject: Reply with quote
October 7-10th. I wil be there the 8th and the 9th. It is in various places, but the main meeting place is the Luxur back parking garage. You will find lots of supras there.
PostPosted: Fri Oct 15, 2004 2:09 pm    Post subject: still not fixed Reply with quote
I still have the problem. New cap, rotor. A few vacume lines.
I ave been starting to hear a leak in my exhaust manifold Could this be my problem?
Does a 5M fit or do I need a 7M exhust manifold?
PostPosted: Fri Oct 15, 2004 2:19 pm    Post subject: Reply with quote
don't know. Run a compression test. Make sure you are all up to par
PostPosted: Sun Nov 21, 2004 10:54 pm    Post subject: Update Reply with quote
I'm still in Vegas. Went to the hammers in Oct. It would still miss there. Never did a compresion check. Tried a few more things some people sugested. I can't remembe what it was but it did't help.
Then once I got back to Vegas it fixed it's self. I don't know why but it has been running fine for about a month.
Untill today when I drove it in the rain. Out of the blue the check engine light started flashing code 42. It still runs fine.
So anyone want to look that up for me?
PostPosted: Mon Nov 22, 2004 10:30 am    Post subject: Reply with quote
vehicle speed sensor.
Would only cause stalling after hard acceleration then coming to a stop.
PostPosted: Mon Nov 22, 2004 10:31 am    Post subject: Reply with quote
I still have my bets on a ground.
Check all the wires going to the ground connector on the intake manifold.
The wires often get corroded and break.
Also, check all your ground points. Make sure the body is well grounded too.
PostPosted: Fri Aug 31, 2007 6:44 pm    Post subject: Update, sort of Reply with quote
Well now #6 is not working. I have spark, and the injector is clicking. Any ideas? I put some seafoam in it, gas and oil. It did miss when I first started it this season after it sat for a while. but it cleared up after driving a while. I been thru a tank of gas, and it still misses
PostPosted: Tue Sep 04, 2007 2:35 pm    Post subject: Reply with quote
how do you know it is clicking.
PostPosted: Tue Sep 04, 2007 3:45 pm    Post subject: how do I know it is clicking Reply with quote
I put a long rod on the injector, and the other end on my ear. Stethescope sort of. Acualy it was my shock piston tool I made for my motorcycle.
I am on my way to Vegas agian, this time for Vacation. When I get back I guess I will start to tear the engine down and see what I come up with. Compression is only 30lbs, but I cant tighten the thing in the hole. so it may be leaking since it is only finger tight.
