Auto to Manual neutral start switch?
zachm611Offline
PostPosted: Thu Mar 06, 2008 12:19 am    Post subject: Auto to Manual neutral start switch? Reply with quote
Hi all i bought an auto car originally but i am converting it to manual, i know im suppose to wire up a neutral start switch but im not sure which wires they are. any help with colors or anything is much appreciated. thanks a lot,
Zach
edit: after searching around i found what i was looking for. here it is for everyone else wondering.
In the attached pic, from left to right, you have the following:
1. 3 wire round plug, wht/blk spliced together enable the bypassing of the clutch (ie. pedal pushed in isn't required to start the car) and the blue is 1 of 2 wires needed for the reverse lights
2. 6 wire round plug, this plug actually tells the ECU which gear the car is in. If you searched for "auto cookie" you'll find some more info on what lead to the connections. Anyways, the only wire needed from this plug is the blk one (this is 2 of 2 for reverse wiring)
3. 6 wire square plug. not used for 5 spd. IIRC, it was linked to the 3 solenoids on the DS of the Auto tranny
4. 4 wire square plug, its a direct plug'n'play for car's with an ABS system.
