7m in a 83 toy wont idle...
toysoupOffline
PostPosted: Sun Jun 29, 2008 6:06 pm    Post subject: 7m in a 83 toy wont idle... Reply with quote
Hey all i've been roaming the site for a couple months now, have a 88 7mge swapped into my truck, its a tight fit but got'er done....so i have bypassed using the fuel resistor which i believe should be fine, but i cannot get it to idle, it will start go up to 2000rpms for 3 secs slowly come down then the maf seem to close the door not letting any air into to sustain an idle, then dies out, i now this is all ecu controlled, i've checked the maf it checks out, the tps and the isac also, all sensors hooked up im using a auto ecu but have plug a 5spd in just to see if there was a difference, was the same. Do i need this resistor on the older 88 model? any help would be great can't wait to see wat a power diff it is from the old 22r. cheers kyle
________
NEW JERSEY MARIJUANA DISPENSARY
