MPG
PostPosted: Sun May 22, 2005 3:40 pm    Post subject: MPG Reply with quote
I just got back from GSMTR. I clocked my highway MPG by mile markers since my spedo is broke.
18MPG highway with a 87 4runner. SAS, 35MTR and 529 gears.
hbar314Offline
PostPosted: Sun May 22, 2005 7:13 pm    Post subject: Reply with quote
With what powerplant? What octane gas also since your here?
money for nothin and chicks for free
PostPosted: Mon May 23, 2005 3:26 pm    Post subject: Reply with quote
JDM 7MGE with 87 octane. or what ever is the cheep stuff.
PostPosted: Sun Jun 05, 2005 11:38 am    Post subject: Reply with quote
I can get about 21 on the highway with:
7mgte
91 octane
upgraded turbo
32x11.50's
4.10 gears
The lowest I've seen when I've been getting on it alot in the city is about 12 Smile
YellowJacketOffline
PostPosted: Tue Jun 14, 2005 9:26 pm    Post subject: Reply with quote
MY
7MGTE
91 octane
upgraded turbo
32x11.50's
4.10 gears
Mostly Freeway
I get 13-16 mpg. Not happy I hope something is wrong. Sounds like it is...
87 4Runner - 7M-GTE, SAS, Locked, 8" lift, 35" BFG's, 4.88 gears
82 Toyota Truck - 22RE, 6" lift, 32" BFG's, 5.29 Yukons, locked front & rear, "super-cabbed" SOLD
Blue Ribbon Coalition
PostPosted: Sun Jul 17, 2005 3:34 pm    Post subject: Reply with quote
Mike, 21, that is pretty darn good. Can be hard to get those numbers with our poor aerodynamics
Yellow, 13, not soo good, bring that runner down to my house and we will fix that up. Our wives can go hang out while we fix it up.
YellowJacketOffline
PostPosted: Sun Jan 08, 2006 8:26 am    Post subject: Reply with quote
Rob Help!
Gas mileage just got a whole lot more important, especially if I want to come to your house!
PostPosted: Sun Jan 08, 2006 1:41 pm    Post subject: Reply with quote
Yellow, I think the problem is the speed sensor with you. The supra ECU just doesn't like the 4cyl guage cluster speed sensor
YellowJacketOffline
PostPosted: Mon Jan 09, 2006 7:57 pm    Post subject: Reply with quote
I wonder if we should also hook up my EGR?
PostPosted: Tue Jan 10, 2006 12:40 am    Post subject: Reply with quote
EGR will give you slightly better gas mileage...might bump it up 1-2 mpg
ZrodOffline
PostPosted: Fri Jan 13, 2006 2:08 pm    Post subject: MPG Reply with quote
I had the 7mgte running without power to the black/orange wire on the ecu. I think it was the ignition switch. I ran it like this for about 10,000 miles. The idle control and engine check light did not work in this configuration, but it was consistantly getting better than 20 mpg on average. This was mostly state hwy routes with 55mph speed limits between towns, my daily commute of 40 miles one way. One week, I measured approximately 24mpg. This is with 4:10 gears and 35x12.50 wild country mud terrains.
I have since developed a bad counter shaft bearing and run mostly in fourth. I also finally connected the power wire on the ecu. The idle control and engine check light now work, but I can barely make 18 mpg anymore.
I know fourth gear is not helping. Would the Speed sensor contribute to the poor mileage? If so, what is the correction? Snip the Speed sensor wire?
Rod
78 turboZ
90 SWB, Xcab, 7mgte installed and running.
YellowJacketOffline
PostPosted: Wed Jan 18, 2006 1:32 am    Post subject: Reply with quote
24 MPG???? Are you sure? I think you would be the only one...
PostPosted: Wed Jan 18, 2006 10:07 am    Post subject: Reply with quote
Nate got 24mpg.
ZrodOffline
PostPosted: Wed Jan 18, 2006 12:08 pm    Post subject: 4 Cyl. Cluster Speed Sensor Fix? Reply with quote
YelloJacket, 24 mpg was correct, but it was conservative driving. Throw in some interstate driving with higher speeds and mileage dropped to 19-20 mpg range. That's not what I would consider bad, but now its seems closer to 15-18 with conservative driving in fourth and all the signals to the ecu that I can get from the truck.
Rob, have you determined the difference between the 4cyl cluster speed sensor and the Supra Speed sensor?
Would it be as simple as snipping the Speed sensor input, or maybe a reisistor inline?
Rod
78 turboZ
YellowJacketOffline
PostPosted: Wed Jan 18, 2006 7:25 pm    Post subject: Reply with quote
Nate has an auto, Rod do you have an auto? I though manuals were suppose to get better mpg?
Rob and I just fixed my speed sensor issue last night. It turns out we just needed to splice the right wires together...
