www.supracharged.com This forum is for information on Supra Swaps
| View previous topic :: View next topic |
| Author |
Message |
4RnrRick
Joined: 02 Jun 2005 Total posts: 243 Location: PNW Gender: Unknown |
Posted: Sun Jul 10, 2005 9:15 am Post subject: |
Well I finally found my wiring gremlin! I was getting a 1.3A drain on battery only after I connected the battery and started the engine once.... plus the heater fan would then have power to it after I pulled the key out..... And the other thing that keyed me into a problem was my EFI relay was getting warm to the touch...
Basically when I wired the EFI main relay I just spliced into the main harness where I needed to cut the existing wire and then splice into it. I was getting a weird power feed back though the system that after turned the key for the first time and it would engage the heater relay and then it would send power to the wrong side of the efi relay. It was a PITA to find but I finally did!!!
The other thing I worked on was adjusting the 4cyl tack to read the correct RPM for the 6 cylinder motor. Well that fix was real easyusing this info:
http://www.mindspring.com/~jayk3/toyota/tachmod.htm
But I had one heck of a time trying to figure out what the actual RPM of the motor was! I couldn't figure out how to hook up my dwell/tach meter to the coil to get it to read RPM.... Everytime I hooked it up I was only reading 150-200 RPM. I even borrowed two other meters and they did the same thing. So I finally gave up on that and I was able to wire in the donor car tach from the cressida instrument cluster. but the odd thing about that is that was only showning 500 rpm at idle..... to me it sounded more like 700 ish.... so anyway I then hooked up my 4runner tack and set it accordingly. I would still like to figure out what I was doing wrong so I can compared the actual rpms to the tach as say 3000 rpm.
So I basically spent all yesterday working on those problems.... doesn't feel like I did anything productive!
And here is going to be my last entry on my actual costs. I don't expect to be buying anything else for this motor swap. I've also still have about $200-$300 of more stuff off the motor that can be sold. so that would put my total cost for this motor swap and dual batteries around $1700-$1800.
| Code: |
[font=courier]
*...4RnrRick's list of actual motor swap costs...*
*.........Prices Include Shipping Costs..........*
*.Descrpition..............................Price.*
*7M-GE engine 89 Cressida 153K w/ 90 day warranty*
*from local wrecking yard. Motor harness w/ ECU,.*
*coil/igniter, injector resistor, AFM, Exhaust ..*
*manifold, 02 Sensors, Oil pan, pickup, dip stick*
*Supra 7M 5MGE upper motor mount brackets, 5M/7M.*
*bellhousing, flywheel, clutch fork, slave cyl...*
*starter, and every else typically supplied with.*
*a motor swap............................$950.00.*
*Motor credit for Bad Head Gasket.......($115.00)*
*Radiator, new 1988 V6 3-core, 2" thick..$115.00.*
*14" Electric Fan, Hayden #3710..........$139.99.*
*185F Thermostat Relay, Hayden #3652......$22.99.*
*Radiator hose, NAPA 8761.................$17.92.*
*Radiator hose, NAPA 8698.................$11.73.*
*Radiator hose, NAPA 7775.................$12.16.*
*Radiator hose clamps......................$6.33.*
*Material for splicing Radiator hose.......$4.99.*
*OEM Replacement Clutch Kit..............$150.00.*
*Resurface flywheel and exhaust manifold..$70.00.*
*Clutch Slave, 'Napa' #37606..............$30.90.*
*Head Gasket, FelPro #9473PT.............$102.73.*
*Valve Cover Gasket Set, #ESP VS50303R....$21.14.*
*Front Crank & Timing Gskt Set, #TCS45732.$24.28.*
*Rear Main Seal, Knecht's #ESP 228010.....$16.35.*
*Exhaust Gasket, Knecht's #ESP MS92327....$12.46.*
*Intake Gasket Set, Knecht's #ESP S93544..$11.72.*
*Cam Shaft Seal Set , #ESP45424...........$11.03.*
*Oil Pan Gasket, Knecht's #OS 3435........$10.58.*
*Bulk Gasket material......................$2.99.*
*Exhaust Downpipe Donuts, Napa F-14592.....$6.28.*
*2 1/4" Exhaust connector for collector....$3.07.*
*Professional Exhaust with muffler.......$300.00.*
*Spark Plug Wires, Knecht's #ESP 09216....$63.88.*
*Distibutor Cap, Knecht's #KEM W3082......$10.79.*
*Spark Plugs, Knecht's #NGK 2241 Qty(6)....$9.54.*
*Rotor, Knecht's #ESP JR120T...............$5.08.*
*Timing Belt, Knecht's #CLO B126..........$18.48.*
*Alternator Belt, Knecht's #GDY 510K5.....$12.59.*
*Power Steering Belt, Knecht's #GDY 350K4..$7.20.*
*1989 Supra 7M-GE oil pump, new (ebay)....$85.25.*
*1989 Supra oil pump hardline.............$39.61.*
*1989 Supra oil pump ball sleeve & gasket..$6.11.*
*Fram Sure Oil Drain Plug, 18mm x 1.5.....$15.69.*
*Antifreeze................................$9.99.*
*10W-30 oil...............................$10.20.*
*Dot 3 brake/clucth fluid..................$3.40.*
*Power Steering Fluid......................$2.99.*
*Used 210 York from Volvo (V-Belt)........$30.00.*
*New 6 gr pulley&clutch, Kenworth KA1480..$69.95.*
*Red Top Optima Battery...................$93.00.*
*Battery tray & hold downs................$11.98.*
*Battery marine terminals..................$1.98.*
*Battery isolator, 95 amp.................$39.99.*
*6 Amp Circuit Breaker.....................$4.77.*
*(6) Fuse holder, 'Accele' #5415..........$14.95.*
*Battery Wire Lugs.........................$1.98.*
*Wire loom, black split - 3 sizes.........$15.96.*
*Micro Potentiometer 4.7K, RS #271-0281....$1.19.*
*Label Maker..............................$24.96.*
*Vacuum Hose...............................$1.50.*
*Fuel line and hose clamps.................$9.94.*
*Power Steering Hose......................$17.52.*
*Engine Paint, Semi Gloss Black............$4.60.*
*AntiSeize.................................$4.59.*
*Ultra Black RTV, Permitex.................$3.99.*
*Blue Shop Towels, (3 rolls)...............$6.00.*
*Metric Hardware..........................$23.56.*
*Misc Steel from metal recycler...........$17.15.*
*Chain for motor mounts, 5/16".............$3.50.*
*Engine Repair Manual CD 7MGE/7MGTE, ebay.$18.12.*
*Chiltons Repair Manual for 1989 Cressida.$17.95.*
*Borrowed 1989 Supra Electrical FSM on CD..FREE..*
*Borrowed 1991 Supra Electrical FSM........FREE..*
*Borrowed 1991 Cressida Electrical FSM.....FREE..*
*Borrowed Engine Stand and Hoist...........FREE..*
*Sold, Thorley Header with O2 Sensor....($125.00)*
*Sold, Short Block W/ Timing set & pan..($150.00)*
*Sold, Head, DOA 270 Cam, LCE Adjust timing gear.*
*& LCE Red Powder coat valve cover......($150.00)*
*Pending, EFI Conversion Parts..........($225.00)*
*Total Dollars Spent as of 7-8-2005......$2032.56*
[/font]
_________________ Project Quasimodo
'85 Xtra Cab (2wd, 22RTE, Auto => 4wd, 3RZ, w56, 2.28x4.70) |
| Back to top |
supratruck88
Joined: 21 Jun 2004 Total posts: 156 Location: Bel Air, Maryland Gender: Unknown |
Posted: Sun Jul 10, 2005 8:52 pm Post subject: |
nice work, and you get it done quick, took me over a year to do mine, but i waited 8 months for a friend of mine to heal after he broke his leg. I was scratchen my head a few times on the wiring stuff too. _________________ 88 toy 4wd, 7mgte, 32''s, custom bed
My Site http://www.cardomain.com/ride/647331 |
| Back to top |
swank Joined: 04 Jul 2004 Total posts: 92 Location: Port Coquitlam, BC Age: 24 Gender: Male |
Posted: Mon Jul 11, 2005 1:16 am Post subject: |
| 4RnrRick wrote: | The engine doesn't want to idle very well at start up. you have to give it some gas for say the first 5 seconds before it takes the idle. again I haven't tuned anything yet since I'm waiting for the exhuast.
My 5m-ge I got does the same thing. I have to put the gas pedal to the floor then it bogs sometimes as low as 300 rpm for a few seconds then starts reving and catchs the idle. Only does it when the engine's cold. |
| Back to top |
4RnrRick
Posted: Mon Jul 11, 2005 9:28 am Post subject: |
The low rpm on start up is no longer happening..... I think it just had to do with the computer learning itself.....
Well I finally got around to cleaning up and looming the wires.
I also got the computer mounted.
And I was able to wire up most of my accessories. but still need to loom a couple more wires in the driver side kick panel and drive side fender.
So far I have put about 70 miles on this engine. Power is great at lower speeds. Maintaning 65-70 mph on the freeway the throttle is only open 15-20% in 5th gear. Before with the 22RE it would be 80-85% WOT in 4th gear. But over 75mph the engine feels sluggish - Sure thats faster than I should be going but I'm just trying to find all the quirks and bugs in the engine.
One think I did notice when I was timing the engine, I would short the computer and the timing wouldn't change. So I ned to look into that more...
Also the water temp gauge is constantly cycling going up and down. I didn't replace the thermostat, but I think I should with one that is a bit cooler than stock. and on top of that I keep blowing my 25A fuse for my electric fan, so I need to bump that up a size.
Also for some reason my death wobble is now worse than before! So I've got a couple new Irok's coming for the front axle but unfortionately they're out about a month..... _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Mon Jul 11, 2005 1:46 pm Post subject: |
COMPARISON PERFORMANCE TEST RESULTS!
The baseline tests where done right before I pulled the 22RE out of the 4runner 4500 lbs +/- 10 lbs with an empty gas tank, built 22RE, W56, Dual cases, 1/4" thick drivelines, 5.29 gears, 36" Bias ply IROKS at 15 psi.
I have not weighed the 4runner after the swap (I'm expecting it weighs 80 lbs more due to the engine) and I now have a 1/2 tank of gas (another 50 lbs). Also I have two slow leaks in the Iroks probably due to crap in the bead, So the tire pressure is lower than before.
You won't believe some of these numbers.... Also keep in mind that I timed these myself with a the second hand on my watch. So they are not very accurate but the do show a very impressive increase in performance!
Test #1
0-40 MPH on flat ground
22RE - 10.5 seconds average (2 runs)
7MGE - 7.5 seconds averaage (2 runs) {40% increase}
Test #2
0-60 MPH on flat ground
22RE - 23 seconds average (3 runs)
7MGE - 13.5 seconds average (2 runs) {70% increase}
Test #3
Hillside Drive - mild hill close to the house
22RE - Top speed at crest was 48 MPH in 3rd gear
7MGE - Top speed at crest was 57 MPH in 3rd gear {19% increase}
Test #4
Sunset Drive - really steep hill close to the house
22RE - Top speed at crest was 31 MPH in 2nd gear
7MGE - Top speed at crest was 47+ MPH in 3rd gear* {52%+ increase}
* = I had to let off the gas on one corner of this hill because I was going too fast and actually started to power slide on dry pavement!
Also something to note is that my death wobble is worse now after the swap which is probably scuffing some speed off the results with the 7MGE. _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Mon Jul 11, 2005 11:45 pm Post subject: |
And heres some final dimensions.
Ground to the bottom of the front crossmember.
22RE - 25"
7M-GE - 25"
Ground to the bottom of tranny bellhousing.
22RE - 23"
7M-GE - 24"
Ground to the bottom of the oil pan.
22RE - 20 1/2""
7M-GE - 23 1/4"
Ground to the bottom of Sky's Crossmember.
22RE - 19 3/4"
7M-GE - 20 1/2"
Ground to bottom of Transfer Case Parking Brake Mount.
22RE - 22 1/2"
7M-GE - 22 7/8"
Well these dimensions puzzled me at first because there is no way I gained that much clearance under the rig with the same amount of drive train lift as before. Until I remembered I didn't check the air pressure in my tires on the previous measurement... So these dims are much harder to intepret than by first glance. Basically the pan on the 7M doesn't hang down as far as the one on the 22RE and the 7m appears to be mounted on the frame rails higher since these more clearance under the bellhousing. _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Tue Jul 12, 2005 1:54 pm Post subject: |
Also I was able to borrow a nice digital timing light with a built in tach. I adjusted the POT switch I wired into the M- and M+ terminals on theback of the tach to match at 4000 rpm... then when I check it back at idle, it was 400 rpm off! actualy RPM was 750 and the tach said 1150 RPM ARGH..... So thats a big no go. Guess I'm just going to swap a V6 SR5 cluster in there and be done with it! Anybody got one for cheap..... _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Wed Jul 13, 2005 8:53 am Post subject: |
If you guys remember correctly, the 4Runner weighed 4500 lbs +/- 10 lbs with me in the driver seat and a emtpy tank of gas. Well I just weighed the 4runner at the same conditions..... me in the driver seat and an empty tank of gas....Its still 4500 lbs +/- 10 lbs. The only thing that is not installed on the 4runner is that during the conversion was my new OBA and I removed the AC during the conversion. So I would have to say that a 7m swap will only gain you 30 lbs.......
Also for the first tank of gas I was pretty hard on fuel consumption with my new found power! I got 12.7 MPG which is basically right where I was at before with normal driving of the 22RE! So I'm expecting better mileage on the next tank. _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Thu Jul 14, 2005 10:40 am Post subject: |
Yesterday, I finally got a compression tester extension so I could do the comp. test on the 7M. See with these Heads, you need one of these extensions because the spark plug hole is impossible to get down into to tighten the tester into.
Results:
145, 145, 145, 140, 142, 145
I don't think I've ever seen a motor that consistant.... and I am actually amazed that this was a junk yard motor with a blown head gasket!
As for the spark plugs, they are running lean to me. So I will have to probably tweak with the mixture using the AFM. These are OEM spec NGK plugs have around 150 miles on them.
| Back to top |
SuperRunner Site Admin Joined: 21 May 2004 Total posts: 942 Location: Orem, Utah Age: 33 Gender: Male |
Posted: Sun Jul 17, 2005 3:57 pm Post subject: |
Wow....Wow....and Wow again.
man, this is the most complete set of pictures and info for any swap I have seen.
You should really do a write up and include some pictures.
Well done, and congrats.
You ever going to do turbo? Those 0-60 times will drop by about 50%.  _________________ Supra Swapper and Owner of this site |
| Back to top |
4RnrRick
Posted: Sun Jul 17, 2005 10:51 pm Post subject: |
| SuperRunner wrote: | Wow....Wow....and Wow again.
man, this is the most complete set of pictures and info for any swap I have seen. |
Thanks! I aim to please.... actually I'm just a picture hore and like detailed posts with lots of pictures.
| SuperRunner wrote: | | You should really do a write up and include some pictures. |
This post is way more extensive than any write-up since it literally shows my day by day progress.... your more than welcome to use this info for a write-up on your site......
You ever going to do turbo? Those 0-60 times will drop by about 50%.  |
Naw, I'm kinda concerned right now about breaking stuff. I hate trail carnage! and I'm the type of person that likes push the vehicles as far as I think they can make it. If it had a turbo - I know my carnage list would increase! _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Thu Jul 21, 2005 11:58 am Post subject: |
Second tank of Gas......
155 miles and 11.92 galons
13.0 MPG, Not as good as I would like to see but I still need to look into my timing problem. I don't think the ECU is advancing the spark with changes in RPM. _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Tue Aug 09, 2005 9:22 am Post subject: |
Well heres a final install picture of the 7M-GE in my 85 4Runner...
| Back to top |
4RnrRick
Posted: Wed Aug 10, 2005 1:28 pm Post subject: |
3rd tank of gas now .....
174 miles and 12.99 gallons = 13.4 MPG
Well I definately see a trend here in my MPG.... I hope I can figure it out because I really should be getting more! _________________ Project Quasimodo
| Back to top |
4RnrRick
Posted: Mon Aug 29, 2005 11:28 am Post subject: |
Well, this weekend was its real test. I drove up to TSF (~3 hours away) to run trails all day and then back home. It ran great all day long. Curently the cooling system isn't quite right. Running down the freeway in the cooler morning temperature the engine temp gauge was constantly cycling up and a down. But in the afternoon in the warmer temps it just stayed in the same spot (just below horizontal postion on the gauge). If I was running higher rpms and low speed the temp would climb until the electric fan kicked on. And then it would drop back down to normal and stay there as long as the fan was on. so I just left the fan override switch in the on position when I was on the trails so I didn't have to watch the gauge constantly going up and down. if I was on the gravel roads, I could turn the fan off and it would be fine. so it looks like I need to get a different thermostat and/or a different thermo switch for the fan because its not quite right, but I DO have enough cooling power with this V6 Truck radiator. I just don't like the temps cycling up and down.
As for motor performance, it seems like you can't lug this engine down like a 22R Series. if your keep it about 1200 rpms or more your fine, but any lower than that it seemed to stall out pretty easy. I stalled it out ALOT on takeoffs because I'm just not use to slipping the clutch that much compared to the old motor. Good thing I didn't use a ceramic clucth!!!
For gravel road running, this motor is awesome! I was able to keep the rpms right around 3000-4000 on the roads and on any corner you could lay into the throttle and start power sliding. The throttle around this rpm is also really smooth which is great for drifting because you could stay in control and really control the slide with just how much thorttle you give it. It was night and day different then the 22RE I had. With that you had to work on getting the slide to start with a small jerk of the wheel. and you only had so much power available. And the power band up in the high rpms is REALLY long. You have consistant power all the way up to 6000 rpm. and then when you shift you still have more power. with the 22R series, if you shift out of your gear, your pretty much bogging down and screwed! You can run the roads at lower RPM just fine, its just not as fun for drifting.
I tried some steep hill climbs and really liked how it felt. With this motor if your around 2000 rpm running a steep climb and want to accelerate, you can! just lay into teh throttle a little more and away you go. With the old motor I could do this but no where nearly as fast .
Heres some pictrues from the day....
TSF OHV, 7-up
TSF OHV, Little Crusher
But then on the way home all hell broke loose
Coburg rest stop on I-5
Well so much for this junkyard 7M, I lost the bottom end! Sounds like a rod bearing to me. Luckily I was only about 40 miles away from my house and I was able to make it to a rest stop! So I called up Wheelie_Pete for a tow to his house which was about 10-15 miles. Only to get pulled over my the Finest Coburg Highway Police. (These guys suppliment their city police budget with speed traps on I-5. The state actually had to put a limit on them because they where pulling in too many $$$) Anyways we where informed that it was illegal to tow with a tow strap! go figure...... in the end he said that he wasn't going to cite us, but he said someone else could, basically he said he was going to look the other way. Which was cool.... but it sucked to get harassed like that when all your trying to do is get your junk off the highway!! So after we got it to Petes, I was able to borrow Sky's Turbo Desiel and Trailer @ 11:00pm at night to get the 4runner back to my house. Its not WHAT you know, but its WHO you know!!! Thanks SKY!
So the bottom end is toast in the 7M and luckily I have about 10 days left on my warranty from the wrecking yard so I dealing with them to see whats the next step! _________________ Project Quasimodo
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
