View previous topic :: View next topic |
Author |
Message |
honda_killer Joined: 05 Jun 2004 Total posts: 15 Location: Sierra Vista Az. Gender: Unknown |
Posted: Wed Jun 23, 2004 2:11 am Post subject: question? |
Having read the subject of the 22re mounts and 5mge brackets
in my two wheel drive 93 what should I do about this aparent
1 1/4 raise in motor and engine due to I'm only about 4inches off the ground and it will look pretty stupid to body lift a lowered mini
truck? I don't want to lift the truck or the body because this would
defeat the purpose of making one hell of a street truck?
Please give me any ideas. _________________ Forget the Honda's I want to taste 13's in the quarter mile!! Just because a chevy BB guy told me my truck wont make it into the 15's |
Back to top |
aweber Joined: 17 Jun 2004 Total posts: 30 Location: Perth, Ontario, Kunikistan Gender: Unknown |
Posted: Wed Jun 23, 2004 8:42 am Post subject: Re: question? |
honda_killer wrote: | Having read the subject of the 22re mounts and 5mge brackets
Please give me any ideas. |
As rob said, he never had a problem with the 10 deg driveline angle so I think you should be able to do it no problem without a body mount.... I was making my own cross member anyway so I figured I might as well get the additional ground clearance and stock 4 deg angle ...
PS: You don't need a 7M to beat a honda, you can do that in just about anything  |
Back to top |
SuperRunner Site Admin Joined: 21 May 2004 Total posts: 942 Location: Orem, Utah Age: 44 Gender: Male |
Posted: Wed Jun 23, 2004 10:21 am Post subject: |
http://webpages.charter.net/dbcaudill/webpage.htm
This is a 93 2wd I Helped do out in NC.
No body lift, no modification to crossbar. We just had to take a hammer to the oil pan just a little, and of course there is the firwall clearancing and brake booster.
He could easily take a viper _________________ Supra Swapper and Owner of this site |
Back to top |
Posted: Thu Jun 24, 2004 1:00 am Post subject: |
what about the brake booster what modifications have to be done to the master cylinder? And my 7m came with a egr block off plate and the machinist is thinking of filling in the port on the exhaust to keep from causing turbulence in air flow he is a very good machinist and is letting me help out. the transmission is being gone through by a toyota certified tech from london england and he is going to lap in the gears to help them grab the gears better and new syncros and bearings and locking rings the clutch is probably going to be a SPEC stage three clutch the third member is out of a supra just for the gears (lsd). And what about the throttle cables? which what where? If any body has all of the info on the swap please let me know if you have to e-mail me please do so. robertstoy@cox.net |
Back to top |
Posted: Thu Jun 24, 2004 9:06 am Post subject: |
If you have to do an emission inspection, you cannot fill the EGR port. You have to have an EGR valve. If you don't need emissions, then that will be one less spot you have to take a hammer to the firewall. By the way, this hammer could be a big rubber mallot. You don't have to make the dents noticable.
The problem you will have with the booster is the intake may or may not hit. If you are a 89-new truck, then you will have problems. Pre-89, you should be fine with the clearance.
You should be able to use your existing throttle cable. A custom bracket may be neccesary to mount the cable, but if you have access to a welder and a grinder with a cut-off wheel, modifying the existing bracket is easy. A lot of the time, I will use an N/A bracket on a turbo. The turbo's use linkage, but I prefere to go direct cable. I have also used supra cables too. They mount up to your pedel just the same your trock does(mostly). _________________ Supra Swapper and Owner of this site |
Back to top |
Mike
Joined: 20 May 2004 Total posts: 272 Location: Tucson, AZ Gender: Male |
Posted: Thu Jun 24, 2004 9:33 am Post subject: |
I made my own throttle cable bracket for my swap, and used a NA supra cable. It's pretty basic, here are pics:
Installed:
 _________________ My site |
Back to top |
Posted: Fri Jun 25, 2004 12:32 am Post subject: fire wall? |
What else comes close to the fire wall? So all I need to do is bend the brake booster a little? Or shave the intake a little?
What other things do I have to worry about because the truck is a 93?
We don't have emissions here in S.V. so that I'm not worried about.
On the oil pan do I need to hammer it also or do you reccomend something else that doesn't take a chance in creasing the metal a causing a leak?
And the exhaust is something else I just don't want to take it to Midas or any place really due to alot of people can't keep from telling the world whats going on if you know what I mean. |
Back to top |
Posted: Fri Jun 25, 2004 8:28 am Post subject: |
are you 2wd or 4wd. If you are 2wd, you could just cut a little off the lower front of the pan. If you are 4wd, well, that will take a little more effort. You have to cut the side off the pan, and relocate your oilpickup.
For the brake booster, you could use a booster from an earlier model truck. That is what I did on my runner. No clearancing needed. If not, I would shave a little off the intake. Lots of metal there to shave off. Shave off enough to allow for movement though, otherwise it will drive you nuts, especially in reverse.
The other two places if you don't use an EGR valve would be for the heater hoses. There is one on the top of the head, and one passenger side of the engine. But, it depends on your motor. Toyota made it possilble to make your heater hose come from the drivers or passenger side. Use which side is best for you. Some pipes have been capped off and welded. In that case, you just use the one that is not. _________________ Supra Swapper and Owner of this site |
Back to top |
Posted: Sat Jun 26, 2004 12:01 am Post subject: oil pan |
you don't happen to have any photos laying around about the cuts to the oil pan?
My truck is a 93 hi lux 2wd no power steering or a/c no power locks or windows it weights in at 2550 with me and the spare tire and stereo system.
How much weight will this swap add (turbo,intercooler and engine)
also what about traction the supra lsd will help a little but my suspension
is pretty much already complete. |
Back to top |
Posted: Sat Jun 26, 2004 10:21 am Post subject: |
No pictures of any cuts, but I may have some picture of where we had to dent.
Traction you may have a problem. Since you have a 2wd, you have a 7.5 rear end. You have to upgrade to a 4x4 rear end, but then you will have 6 lug in the rear. Or, you can find a 2wd 1 ton rear, which uses the 8" rear with 5 lug. Then you could drop in a supra LSD. You will also need a traction bar, if not you will have problems with bending your rear springs. _________________ Supra Swapper and Owner of this site |
Back to top |
knucklehead Joined: 19 Feb 2005 Total posts: 8 Location: Columbia, Tennessee Gender: Unknown |
Posted: Sat Feb 19, 2005 10:16 am Post subject: |
Hi new to the board, but I've got a few pics that Derek sent me of his oil pan modification. Can someone host them. |
Back to top |
Posted: Tue Feb 22, 2005 1:55 pm Post subject: |
you have a PM _________________ Supra Swapper and Owner of this site |
Back to top |
dlc Joined: 30 May 2004 Total posts: 6 Location: NC Gender: Unknown |
Posted: Mon Feb 28, 2005 6:23 am Post subject: |
Is this what you are looking for? Doesn't look as bad as the picture suggests
What's going on Knucklehead?
 _________________ 92 2WD Toyota Truck
7MGTE/R154 conversion
00 Tacoma Prostreet 2JZGTE |
Back to top |
Posted: Mon Feb 28, 2005 6:32 am Post subject: Re: oil pan |
Mine was a 92 2wd base truck with nothing (no ac, no power steering, spare tire and jack removed, no rear bumper or tailgate, no radio or speakers, weld draglite wheels, etc) and weighed 2800 lbs. _________________ 92 2WD Toyota Truck
Back to top |
bkubisht Joined: 17 Feb 2005 Total posts: 5 Location: Sierra Vista, AZ Gender: Unknown |
Posted: Tue Mar 01, 2005 10:32 pm Post subject: |
Anyone know honda_killer? It seems I hit the 1 in a million chance that there's someone else here in little Sierra Vista exploring supra swaps. I know his name is Robert, and I tried PMing him with no response. He had a cox.net email address posted once, but that doesn't work. HK, email me at bkubisht@c2i2.com . I'd like to meet up and compare progress! |
Back to top |
