5mge swap done- 1987 4runner IFS
XIHOffline
PostPosted: Mon Apr 09, 2007 9:26 am    Post subject: 5mge swap done- 1987 4runner IFS Reply with quote
87 runner- was 22re and 5 speed.
Motor- 85 block with 82 engine electronics, dizzy and CPU
Wiring- wasn't bad at all. The stock tack had a potentimeter already on it so I just adjusted it. I hacked out what I didn't need from the supra harness and removed that stuff from the truck side engine harness. It was a little sticky because I wanted to prepare the wiring for an eventual 7mgte swap. I have the turbo harness paired down and the 4runner body harness set so it will be a simple motor swap, and just plug in the turbo harness and screw in the CPU to the mounts.
Cooling- I used the radiator that was on the truck already. It is a 4core and even though I don't have my fan on yet the truck never gets over 1/2 on the temp guage.
EGR- I deleted it on this engine since I passed emissions right before the swap. I'll add it back for the turbo version
Oilpan- Stock 5mge supra pan fits just fine if you remove the steeing stabalizer
Misc- used stock 5mge and 22re mounts. Had to install a 3inch body lift to ease install. I also lifted the tranny and t-case 2 inches with a Budbuilt.com crossmember to level out the engine and hopefully prevent some of the oiling issues.
Overall:
It runs good. Power is much better than the 22re. From 1000-3700rpm it is steady and strong, but nothing amazing. For some reason it hits a "powerband" at 3700 and really kicks in from there till I let up at 5500. Don't know if this is normal or not. Wish it had a bit more kick down low.
The only problem I have is that my rear windo stopped working after the swap and for the life of me I can't find anything that I would have touched that could have caused that. I'll try and get som pics up.
PostPosted: Fri Apr 27, 2007 12:21 pm    Post subject: Reply with quote
Yeah, the 5M is an improvement over the 22R, but remember, you are only gaining .4L Not a HUGE jump, and the 5M is only 12 valve instead of 24.
But getting this far means a 7M or 7MGTE is going to be a sinch.
XIHOffline
PostPosted: Fri Apr 27, 2007 12:24 pm    Post subject: Reply with quote
I am getting a full custom exhaust put in today so that is great. I like the power and feel of the motor and even with my flex piped exhaust and 31s I am kickin around 24mpg
PostPosted: Fri Apr 27, 2007 12:25 pm    Post subject: Reply with quote
WOW, that is great MPG, I wish I could have got that.
XIHOffline
PostPosted: Fri Apr 27, 2007 12:32 pm    Post subject: Reply with quote
LOL oh, and my window issue was that damn wiper being a milimeter from the top.
I am went with two 10inch fans and an adjustable controller.
What temp do you guys run? I have my fans set to come on at 195(temp measured at the t-stat housing) and the hottest I have seen it go to is 210 after going from a hard romp to idling...Driving down the highway it is usually at 180 or so
PostPosted: Mon Apr 30, 2007 10:02 am    Post subject: Reply with quote
yeah, I think that is a pretty good temp.
